High or low?
Old Oct 28, 2007 | 07:23 PM
hwks1's Avatar
Default High or low?
Is it better to drive in either high or low all the time if I am always going to be doing low speed riding? How fast can you ride when in low?
Old Oct 28, 2007 | 07:37 PM
caperinmuskoka's Avatar
Ride like you own it, Not like it's stolen!
Default Newbie Question
That is to apply the rear brake ..........The one on the handlebars is the one to use....It controls all three......................two on front and one at the rear!!.....Welcome to the forums......Caper.......
Old Oct 28, 2007 | 07:47 PM
hwks1's Avatar
Thanks! I guess I could have tried that - I assumed it was but I am away right now and I only got to ride it for about 5mins
Old Oct 28, 2007 | 08:11 PM
Carroll B's Avatar
I ride up to about 15 mph on my 500 with it in low. Since my quad is new I want the RPM's to be higher to help the belt break in properly. On the first trail ride I went on I ran in low about 60% of the time, stopping to put it in high when I knew I could get over 15 mph. Your quad has a rev limiter to prevent the engine from turning too fast in low.
Old Oct 28, 2007 | 09:39 PM
hwks1..........What happened to your first question............It is gone off the forum??...........Caper.......
Old Oct 28, 2007 | 10:58 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
<div class="FTQUOTE"><begin quote>Originally posted by: caperinmuskoka
hwks1..........What happened to your first question............It is gone off the forum??...........Caper.......</end quote></div>
yea i was trying to figure out what you were talking about there lol. if going around 7 mph alot use low to keep the belt cool.
Old Oct 28, 2007 | 11:48 PM
hwks1's Avatar
I tried out low - couldn't tell much difference but I do see that you don't get as much speed but it wasn't what I was expecting because you can still do 20mph. I'm thinking I would just leave it in low all the time
Old Oct 29, 2007 | 12:55 AM
jdaddy's Avatar
hwks, i recommend you read your owners mannual bro, if you run around in low at speeds faster than 7mph you'll decrease the life of your belt, for most typical riding high is the way to go. just my opinion.
Old Oct 29, 2007 | 02:23 AM
sheepdogMSP8117's Avatar
H should be the first gear of choice. If you find that the load is such that you're using lots of throttle to maintain a lower speed, that is when you should use L. Don't be afraid to use H.
I've had my 500 up to 15 mph in L for short periods. I do all my snowplowing in L. I also use L when I'm in mud or on steep uphill climbs, etc. I've had my 800 up to 20 mph in L for short periods. But normally I use H on both, I'd say 80% of the time on any given ride.
Old Oct 29, 2007 | 06:31 AM
upnort's Avatar
With sheep here, with the addition of pulling loads and technical terrain. Running in high under these conditions may cause your belt to burn. About 15 tops in low if you hold it open in low you should hear it start to miss when the rev limiter kicks in.
