High or low?
Old Oct 29, 2007 | 07:36 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
Default High or low?
like i said using low going @ a slow speed under say 7 mph +- is so it will turn the rpms up enough to effectively cool the belt. if your going to pull something heavy or go thru hard terrain(going slow) you also should use it. the down side is that it uses alot more gas being in low as the engine is turning up more. this will be in the owerns manual for sure.
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
fredrikrosen
Sep 28, 2015 09:58 PM
r1pilot83
Sep 27, 2015 07:38 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
