battery?
Old Nov 10, 2007 | 01:02 PM
attitudeadjuster13's Avatar
Default battery?
i have a 1994 sportsman 400 had charging problem, now have new battery in it found out stator is probly bad was wondering if when im not riding if i could use a battery tender? the only time i use the battery is for the winch to plow[img]i/expressions/face-icon-small-confused.gif[/img]
Old Nov 10, 2007 | 05:03 PM
hoytultratec's Avatar
Default battery?
you need to fix the machine, a winch uses alot of juice so you need a to have the battery charging while you are plowing so it doesnt drain it completely also running that machine with a dead battery will burn out all the light bulbs and possibly the cdi.
Old Nov 10, 2007 | 05:24 PM
Polarisitis's Avatar
Default battery?
Lead acid batteries needs to be kept fully charged.. always.
If the charging system is not working, charge the battery after every use until you fix the problem.
An SLA ( Sealed Lead Acid ) battery left in a discharged state will quickly " sulfate " and become rather useless in short order.
pgamboa
Dec 24, 2023 11:52 AM
Cdenton
Technical and How-To Articles
Sep 9, 2015 11:23 AM
Steeldon
Sep 9, 2015 09:38 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
toonces
Sep 5, 2015 01:14 PM
