best pipe for trail boss / blazer
Old Nov 10, 2007 | 06:41 PM
ninjatarian's Avatar
Default best pipe for trail boss / blazer
i own an 88' trail boss 250 4x4 (same engine as trailblazer). i want performance pipe for it but not sure whcih would be best. i plan on putting slightly larger and more aggressive tires on it. i found two different pipes made by DG for that motor and some silencer options. i also found two pipes from another company. i cant find any specs on the dg pipes or reviews of any kind. here are some links-
dg 1
dg 2
dg 3
other company
Old Nov 10, 2007 | 11:12 PM
ftwflh's Avatar
Dont worry about a pipe just clutch the thing then go with a good air filter.If you must pipe it call Rick Ritter @RcR
Old Nov 10, 2007 | 11:20 PM
i just found the rcr stage one kits for the trail blazer. I'm considering one of those now. i didn't even think of the clutching, thanks for the suggestion
Old Nov 10, 2007 | 11:31 PM
ftwflh's Avatar
Puta polaris white primary spring in the old girl and go for it.The spring is a stock primary spring for a 2000 400 scrambler
Shainasmash
May 8, 2017 06:38 PM
Anomers
Aug 16, 2015 11:06 AM
Backwoods_badass
Aug 2, 2015 10:40 PM
Backwoods_badass
Aug 1, 2015 10:25 PM
Gnuters
Jul 19, 2015 10:03 AM
