moto 4 carb help
Old Nov 12, 2007 | 07:50 PM
bigb9582's Avatar
Default moto 4 carb help
can some one tell me the factury settings for the a/f mixture screw and what notch the needle should be at for a 86 or 87 225 moto 4.
got one that im workin on and the prev. owner got the carb all screwed up.
thanx for any help
Old Nov 13, 2007 | 11:02 AM
bigb9582's Avatar
no one knows?
Old Nov 13, 2007 | 07:07 PM
1950truck's Avatar
Pilot screw set at 1 1/2 turns out and Jet needle in position 3 which is the center position.
Old Nov 13, 2007 | 08:14 PM
bigb9582's Avatar
awsome thanx u.
i was gonna put the needle in the middle and set it to 2 turns, but now i no were to start. thanx again
Old Nov 14, 2007 | 07:14 AM
1950truck's Avatar
Good luck. Make sure you blow out every little jet, port and passage before you reassemble the carb. I just had a similar situation with a yfm200. I probably removed the carb a dozen times before I finally got it to run. Buy a Clymer manual. It's some of the best money you could spend. Happy motoring!!
GregM
Mar 6, 2018 06:53 AM
GregM
Jul 29, 2015 09:41 PM
Aitch
Jul 21, 2015 09:40 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
