WOLVY LIFT KIT: QUESTION!!!
Old Nov 12, 2007 | 11:25 PM
ross.graziano
Guest
Posts: n/a
Default WOLVY LIFT KIT: QUESTION!!!
I am about to order the Perfex lift for my 2007 Wolverine SE, does antone out there have one of these yet and how is it? Is it just a body lift?
Old Nov 12, 2007 | 11:41 PM
Honeyduck96's Avatar
If it's like other straight axle lift kits, it will just be a shock spacer out back to push your swingarm down further from the rear fenders. No ground clearance is gained, but it will allow you more body clearance to run even bigger tires than you normally could. I wouldn't bother with it on the Wolverine, as you have pretty good clearance anyways with the 27" tires
Old Nov 13, 2007 | 08:39 AM
ctateusa1's Avatar
It does smooth out the ride a little bit is what I have heard before, by changing the angle of the shock. But it will lift the wolvy by about 1/2-3/4 inch
Old Nov 13, 2007 | 08:42 AM
ctateusa1's Avatar
crap I was talking about the long travel suspension kit, the lift kit give you more lift but like he stated you already fit the 27's so unless you just want to get the engine up a little more to ride higher in the water or mud you dont really need it.
shimanok2
Jan 29, 2016 07:37 PM
QuadRiders
Oct 22, 2015 04:13 PM
bigred20653
Oct 2, 2015 10:05 AM
Nosniborpapa
Sep 19, 2015 07:07 PM
bigred20653
Sep 19, 2015 02:11 PM
