Mixing my own fuel?
I want to know if I can mix my own fuel and pre mix instead of using the oil injection system. Injector oil stinks royally! I used 100 octane and Castor 927 in my kx 250. That smells much more pleasent. Its all poison anyway but at least I can poison myself and it will smell better. I was told I would have to disable the oil injection pump because it would lock up. Where would I get a block off plate for this? Sure wish I could just run my castor through the system.
My dad mixed his own oil in his scrambler 400. All you have to do is plug the oil tank hose and figure out what ratio you want to mix your oil. He disabled his after he blew it up due to it wasn't oiling enough after putting a pipe on.
Elkaholic
Sep 6, 2015 02:44 PM
