Trail Boss 330 help
Old Nov 14, 2007 | 06:45 PM
2stepn's Avatar
Default Trail Boss 330 help
I have a 03 trail boss 330 and I would like to set the idle mixture.
First, On the wiring diagram I see that the rev limiter receives an rpm signal from the charging coils. What type of tach can I connect to This. I have a traditional automotive diagnositc tach with the 4,6,8, signal choices. Can I set it to 4, do some math and get the rpm or do I need a different tach for this signal?
Second, I have removed the plug covering the pilot screw. Getting to the pilot screw to adjust is another story. I've sort of come up with a way, but I'm hoping that someone with experience on these has a good way to approch this and can share their ideas.
Thanks
Bill
Old Nov 14, 2007 | 07:25 PM
94harley's Avatar
The plug will need drilled out to get to the idle mixture screw. It's not fun to get to either. No room. I bought a special tool from Motion Pro to be able to adjust them. It wasn't cheap either, but it does work WELL.
As far as your tach, I don't know if it will work or not. Try it, see what it says. I have a Mac timing light/tach I use for RPMs.
Old Nov 15, 2007 | 01:04 AM
ftwflh's Avatar
I use a TinyTach for clutch tuning on these they hook up easy but pich up a little slow.
oliveiracarlos
19
Nov 11, 2015 05:49 AM
craacker
Sep 9, 2015 04:32 AM
awer1968
Sep 8, 2015 11:02 AM
Elkaholic
Sep 6, 2015 02:44 PM
Canamaniac!
Sep 4, 2015 06:44 PM
