Help with 650 V2 Carbs
Old Nov 16, 2007 | 06:59 PM
rolesdsracing's Avatar
Default Help with 650 V2 Carbs
I have a 05 650 V2, I cant get to run right, It idels good but try to drive and get a max of 10km/hr, I removed the air box cover and my Vacuum pistons do not move when i rev up the engine, I have removed the diaphragm & needles & every thing looks good, No crack or holes, I read on a previous post that there is a seperate vacuum hose that goes to the side of the carb but am unable to locate.
Old Nov 17, 2007 | 11:02 AM
v2rider's Avatar
Put your hand over your snorkel once and try. If no luck there, try putting stock cdi back in, and i would suggest running a can of seafoam through it. You can dump a little of it VERY slowly down the throat of the carb while its running, and expect a little smoke from the exhaust, thats normal. Dump the rest into your gas tank. Just a few easy checks.
Old Nov 17, 2007 | 09:00 PM
kitty05's Avatar
It sounds like you are in limp mode. but I will tell you that it wont run with the air box lit off. It will idle and that all.
Old Nov 18, 2007 | 04:56 PM
it does run with the airbox lid off, when ideling or when i rev it up, there is no backfire at any time. but my vacuum pistons in my carbs dont move not letting air into the engine.
GregM
Mar 6, 2018 06:53 AM
GregM
Jul 29, 2015 09:41 PM
ghost civic
Jul 27, 2015 03:15 AM
Aitch
Jul 21, 2015 09:40 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
