Help with 650 V2 Carbs
I have a 05 650 V2, I cant get to run right, It idels good but try to drive and get a max of 10km/hr, I removed the air box cover and my Vacuum pistons do not move when i rev up the engine, I have removed the diaphragm & needles & every thing looks good, No crack or holes, I read on a previous post that there is a seperate vacuum hose that goes to the side of the carb but am unable to locate.
Put your hand over your snorkel once and try. If no luck there, try putting stock cdi back in, and i would suggest running a can of seafoam through it. You can dump a little of it VERY slowly down the throat of the carb while its running, and expect a little smoke from the exhaust, thats normal. Dump the rest into your gas tank. Just a few easy checks.
