Clutch removal
Old Jan 8, 2001 | 06:43 PM
gerbert's Avatar
I have a 1996 Magnum 425, and I am trying to remove the clutch. Is there any special tools required to remove the back plate (the one nearest the engine)? Thanks
Old Jan 8, 2001 | 08:33 PM
x_scrambler3's Avatar
They have a puller that screws in to the center of the clutch where the both gose.
Old Jan 9, 2001 | 01:49 AM
Deej's Avatar
Correct, a puller is required.
The end of the crank and the inside of the clutch are tapered so that sucker can be on there good. The puller is inexpensive and will ensure no damage. See your Polaris dealer.
DJ
Old Jan 11, 2001 | 05:02 PM
Farmr123's Avatar
To get the pulley off the engine, you can use a 3/4 inch fine threaded bolt (grade 5 or 8) as a puller. Try to find one with a lot of threads if you can.
To seperate the pulley halves require special tools, and a lot of grunt.
ghost civic
Jan 15, 2020 07:43 AM
merryman
Jan 19, 2016 04:29 AM
Lpshann
Sport Quads
Jul 29, 2015 08:11 AM
ghost civic
Jul 15, 2015 10:48 PM
200es
Jul 10, 2015 09:09 AM
