Carb hose ???
Old Nov 19, 2007 | 08:29 PM
sassee's Avatar
Default Carb hose ???
HELP! I took this thing apart weeks ago to repair tranny and can't remeber the hoses! I have a 97 Trailboss 250. I know which one is the gas line and then there is a bigger vent pipe next to where the choke cable goes in. THEN ther are 2 other hoses that are connected together by a Y. One goes goes to bottom of bowl (Vent I assume) and the other goes on side back towards air box connector. Like I said, these 2 are connected by a y connector with a single hose at the end. WHERE DOES THIS HOOK-UP TO OR ARE THEY JUST VENTS?
I don't have a manual that shows how the hoses are routed.
Thanks!
Old Nov 19, 2007 | 09:11 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
they should be vents if there small dia. hoses. maybe the other hose is a return line or vacume line. they may go up towards the handle bars as thats the highest point. just a guess mind you w/out looking lol.
Old Nov 19, 2007 | 09:19 PM
sassee's Avatar
They are definitley small diameter with what looks like a filter in the single line where it comes off of the y-connector. The "filter" says "Vaccuum" on one side. I cannot find any other place on the ATV to connect it to. I'm not sure which side should be vacuum or where (if any place) it connects???
Old May 29, 2008 | 04:31 AM
wartdog's Avatar
i had the same set up on a 250 trail boss one went to the vent by the choke cable and the other went to the one by the air screw, on the other hand i got a replacement carb and the choke vent is connected to the float bowl overflow??? now i cannot start the dam thing with either aaaaaargh??!!??!!!
SDR-II
Sep 29, 2015 01:06 AM
mdrkcckv
Jul 22, 2015 09:10 AM
Aitch
Jul 21, 2015 09:40 PM
ghost civic
Jul 20, 2015 12:36 PM
Unzzy66
Jul 11, 2015 10:01 PM
