500 HO Reart Wheel bearings
Old May 28, 2008 | 09:59 PM
snowmann's Avatar
Default 500 HO Reart Wheel bearings
i am replacing my worn rear wheel bearings and need to know if these are something you can push in manually or if they need to be pressed into place...i have not done this before and really don't know if they are difficult to remove either...anyone wioth any experience on this?
Old May 28, 2008 | 10:57 PM
plumbob's Avatar
Yes,you will need to have the old ones pressed out and the new ones pressed in. The dealer should be able to do that for a minimal charge.
Old May 29, 2008 | 12:53 AM
contentsunderpressur's Avatar
Some people try to beat them in but I do not recommend that. If the bearing gets a little off center it will mess the hub up. I've changed a lot of these and always used a press. If you take the hub off and to any automotive shop they can press the old ones out and new ones in in a few mins.
Old May 29, 2008 | 07:11 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
im as always im cheap so i do it the old fashion way but its not very easy and yes they are pressed in for sure.
Ean
Dec 19, 2022 08:48 AM
STLyamwar
Jul 25, 2020 04:44 AM
Cantbuytime
Aug 16, 2015 09:13 PM
toonces
Aug 5, 2015 05:55 PM
