lights flicker
Old Nov 19, 2007 | 10:00 PM
02huntinquad's Avatar
Default lights flicker
my 02 s-man 400 has a problem with the lights flickering along with the the speedo jumping around and while it's doing this there is a clicking noise coming from the front of the machine, is there a solenoid behind the rad cover that is maybe screwed????
Old Nov 19, 2007 | 11:11 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
the only thing up front would be the recifier as the solnoide is back by the battery. while its doing it put a voltage tester on it to see what it reads. maybe the voltage recifier is going bad. if its over charging it could take out the the electronics so i would check it if you can. just an idear.
Old Nov 20, 2007 | 06:57 AM
RolliePollieOllie's Avatar
Make sure your ground is clean & tight at the battery as well.
95wolv
Sep 27, 2024 12:00 PM
wendal
Sep 7, 2019 06:46 AM
hueby
Nov 6, 2015 11:34 AM
panicmanic
Sep 28, 2015 12:59 PM
Alex G.
Sep 16, 2015 12:13 PM
