Got the Trailboss running this evening!
Thanks to those that have offered help getting the Trailboss going. I normally wouldn't have bothered with a ATV project this time of year but something about that 2-stroke captured my attention!
The ATV hasn't run in over 3 years according to the previous owner. I bought it as a rebuild project knowing there was a tranny problem. Rebuilt the tranny but haven't bought remainder of items needed until I heard it run. Well, got the carb and fuel system cleaned-out and gased it up tonight and it fired right up. the 2-stroke purred well.
One slight issue, when I try to crank with the starter, it turns over a little then the bendix kicks out and it just spins! It even backfired a couple times. It cranks fine with the rope, but the rope is a little too solid for my 10 year old to pull! At first it didn't want to even spin but I noticed a lot of crud on the cable ends and cleaned them off. Now it spins but kicks out. Any suggestions??????
HAPPY THANKSGIVING!!!
Make sure your battery is 100% charged. If it's not, your starter will do the thing you describe. Test it by putting a battery charger on it and crank it over. See if it still kicks out.
Thanks for the info!
Actually, i think I answered my own question in my post??? I should have thought a little bit more when I had to clean the rust and crud off of the battery cables and battery posts. I checked the voltage at the starter and I'm only getting 10.2 volts when the battery itself is showing 13.5. I believe I have some more dirty connections along the way. I'll get those cleaned up Saturday since we're about to head out of town for Thanksgiving.
Happy Thanksgiving everybody!
Ringwood
Jun 27, 2015 03:02 PM
