More power from 00' 400EX
Old Dec 10, 1999 | 05:18 PM
ruffridaz's Avatar
I was wanting to know what I can do to get some more power out of my 400. I already have a White Bros. Pro-Meg Exhaust and am waiting on my K&N Power Kit (on backorder). I'd like to have the Big Bore Kit but that's too much money to spend all at once. I would rather modify it one or two parts at a time. The next thing I had planned was a track cam and a White Bros. Rev-Limiter. I would appreciate any suggestions.
Old Dec 10, 1999 | 06:22 PM
RoostKing's Avatar
The first thing any 400 EX owner should do is check to make sure you are getting full throttle. Some members of this board have seen a 30-40 % increase in power by adjusting the throttle correctly.
RoostKing...
p.s. this is not a joke.
Old Dec 10, 1999 | 06:52 PM
ruffridaz's Avatar
I've already checked my throttle and It's wide open.
Old Dec 12, 1999 | 02:56 PM
Jeaner's Avatar
I hope you have not installed the pipe yet without the jet kit. i know a couple of people who did that because the pipe manual said it wasn't necessary but now the have holes in the piston. running lean is a VERY bad thing. some people are even weary about changing the filter without rejettnig. if you have read the january issue of DIRTWHEELS they did a test on the white bros. 440 kit and they were very impressed.
Jera '00 400ex
Old Dec 15, 1999 | 05:33 PM
ddog400ex's Avatar
You'r on the right track, I went with the w/bros hop up kit. It works great.Cam, filter,piston,rev limiter and pipe. I race local pro classes mostly against banshee's and 250r's. It's very competetive. I win some and lose some.
Old Dec 16, 1999 | 12:49 AM
hakmazter's Avatar
What if someone bought the WB/IMS big bore kit for $285.00? What else would a person need to do if they didn't want to do anything else (i.e. stock pipe)
Old Dec 17, 1999 | 04:56 AM
norm440EX's Avatar
With the IMS big bore kit you would need a cam, rev limiter, aftermarket filter, and definitely a bigger carb.
Old Dec 24, 1999 | 04:52 AM
Sickyl's Avatar
Roostking, you are absolutely right, while perforing a twist throtle conversion, i happened to notice with the cover off the side of the carb, it would only go to about 90% throttle... no wonder jetting it was such a hassle
Old Dec 24, 1999 | 06:04 AM
RoostKing's Avatar
I do not own a 400 ex, but I have seen many instances on this board where a throttle check performed wonders...
HAve a Mery Christmas,
RoostKing...
2quiker
Mar 22, 2022 08:36 PM
Steeldon
Sep 9, 2015 09:38 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
Logan Collins
Sep 5, 2015 08:03 PM
toonces
Sep 5, 2015 01:14 PM
