2006 Prairie 360 4x4
Old Nov 26, 2007 | 08:52 PM
motarded1's Avatar
Default 2006 Prairie 360 4x4
Reset check belt light and still no luck. I've reset the light by following instructions as per high lifter forum. And still nothing. My 4x4 light was on and it worked to reset that light but not the check belt light. I ohm checked the switch on the belt cover and everythings fine with that. Has anyone else had any problems or suggestions as to what i should try?? Any help is appreciated, Thanks
Old Nov 30, 2007 | 07:41 PM
Hayashi's Avatar
You may be confused. Did you use the 4x4 light reset procedure to reset the belt light?
Is the belt light steady ON or Flashing?
Also, 07 P360 requires different belt light reset procedure from the previous years.
What model year do you have?
You may PM me for more detail help if you want.
ReconBayou
Oct 16, 2019 02:24 AM
akguy31
Aug 31, 2019 04:34 AM
hueby
Nov 6, 2015 11:34 AM
PrairieDog126
Sep 12, 2015 05:23 PM
snowolson
Aug 31, 2015 03:51 PM
