05 700 efi overheating?
Old Nov 27, 2007 | 11:55 PM
joelykool's Avatar
Default 05 700 efi overheating?
When I fill my overflow bottle when it's cold and go for a 10 minute run, the bottle will be empty or just an 1/8 inch of coolant on the bottom of the bottle. Is it a bad head gasket. No message over comes up that tells me it's hot. Sometimes the coolant spews out of top and other times i'm not sure where the coolant went.
Old Nov 28, 2007 | 12:34 AM
RickCJ7's Avatar
You should only fill to the full mark! If that is OK and you see no leaks it could be the head gasket.
Old Nov 28, 2007 | 07:08 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
the only way it comes out the top of the bottle is from heat expention from too much in the(should be between the 2 lines when cold) bottle or from overheating which it would be shooting out the vent hole. if this is happening make sure the fan is working and the rad. isnt plugged back and front. if noe of the above applies then its leaking or going thru the engine. check the oil to make sure its not in there.
Old Nov 28, 2007 | 07:55 AM
jp1's Avatar
jp1
If you had a head gasket leaking that bad you would be able to smell a sweet smell from your exhaust. The burning of antifreeze. Plus your oil will start getting a brown tint to it.
Old Nov 28, 2007 | 12:38 PM
joelykool's Avatar
okay thanks guys. I took it into the dealer this morning and we'll see what the verdict is. This site is great!
Old Nov 28, 2007 | 02:01 PM
heller1's Avatar
I disagree! I blew 2 head gaskets on my old 500HO. Never any antifreeze in the oil or smoke. It drove me nuts trying to figure it out. It wasnt leaking into the cylinder, but on compression stroke, air was blowing by the head gasket into the water jacket causing a buildup of pressure and a fountain out the overflow bottle. I would do as Stendori says and make sure the radiator is VERY clean. if you still have problems, run it with the radiator cap off and look for alot of bubbles. If you see this, you have trouble!
Old Nov 28, 2007 | 10:30 PM
trailbound's Avatar
I had a problem with the head gasket on my twin and with the oil seal behind the water pump. Both times I got water in my oil. Let it sit overnight and then pull the drain plug. If there is water in the oil it will settle to the bottom and come out before the oil. It also presurized the cooling system and shot the water out of the overflow bottle without overheating the machine as heller1 says.
Jenn1
Sep 8, 2015 09:16 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
MikeyBoyesq
Aug 10, 2015 11:11 AM
cornermike
Jul 30, 2015 06:37 AM
