Technical and How-To Articles Post your Tech Tips and How-to articles here. Photo illustrations welcome
winter startup tips
Old Nov 29, 2007 | 09:48 PM
kickit755's Avatar
Default winter startup tips
any1 have any tips on easier start up in cold weather ive killed my battery twice tryin 2 start up so any help eh?
Old Dec 1, 2007 | 01:23 AM
KQ_dagen's Avatar
I run Honda 0W30 synthetic per my dealerships instructions in my 2004 Honda. Starts all winter at 20 below.
Old Dec 1, 2007 | 11:02 AM
hondabuster's Avatar
It helps to know which quad youre talking about.
Some have auto chokes, some have primers and some have heaters.
Before the weather turns cold, is a good time to prep for winter. Clean and reoil the air filter, change to a lighter weight oil, and put in a new spark plug.
On some quads, like the honda utes, pull the primer **** a couple of times, pull the choke on, and it fires right up.
If the quad is reluctant to start, then some can be started by bump starting, which is the easiest on the motor and battery.
Since CV carbs came onto the scene, chokes have disappeared, and been replaced by enrichener circuits. Real chokes work much better for starting in the cold, but if you hold a mitten over the snorkle, of the air box, that will act like a choke, and make the motor easier to start. Some quads are easier to do than others, and some cant be choked off by a mitten.
If these dont help, then you probably have a partially plugged, pilot jet, or the intake valves need adjusting..which are the 2 major causes of no start.
Old Dec 1, 2007 | 05:40 PM
kickit755's Avatar
new ngk plug seems to make a big diff.
woo!
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
r1pilot83
Sep 27, 2015 07:38 PM
exmotocrosser
Sep 26, 2015 08:18 AM
MikeyBoyesq
Sep 22, 2015 10:02 AM
cornermike
Sep 10, 2015 08:30 AM
