Technical and How-To Articles Post your Tech Tips and How-to articles here. Photo illustrations welcome
Grizzly 660 problem Please Help!
Old Nov 30, 2007 | 04:36 PM
acsp133's Avatar
Default Grizzly 660 problem Please Help!
New to this site but hopefully someone has delt with this problem before. 03 Grizzly 660 that starts and idles but when given some throttle it backfires and sputters like it is hitting a rev limiter. Nothing out of the ordinary happened to it, just started over night. Have tried all the usuall suspects. Any advice is greatly appreciated.
Old Nov 30, 2007 | 04:44 PM
kickit755's Avatar
blown piston ring maybe?
Old Nov 30, 2007 | 07:28 PM
jleo's Avatar
did you check the spark plug?
Old Nov 30, 2007 | 10:02 PM
acsp133's Avatar
Thanks for the advice guys, but I have run down all of those. I've been through the carb numerous times and looked at evrything. Compression is 120 psi with 3% leakdown so I know it is not a compression/valve issue. I checked the valves today and adjusted them back into speck. Running on empty for ideas so keep em coming please.
Old Nov 30, 2007 | 10:28 PM
BMotorsports's Avatar
Did you test your spark as far as if it has gotten weak. Another would be to check the timing.
Old Nov 30, 2007 | 10:57 PM
kickit755's Avatar
could be could be.......well it has to b something.........checking the spark/timing sounds good 2 check over see what you find
speaking of spark i bought a new NGK plug today woo!
Old Nov 30, 2007 | 11:50 PM
hondabuster's Avatar
Check the rubber diaphram at the top of the carb for leaks. My bet , is its installed pinched, or it has a pin hole or rip.
Old Feb 10, 2008 | 03:07 PM
m&vtowing's Avatar
have you figured it out yet? mine is doing the same thing and i cant figure it out.
Old Feb 13, 2008 | 02:06 PM
m&vtowing's Avatar
anyone?
Old Feb 13, 2008 | 02:33 PM
Got plenty of gas? Tried reserve position? Cleaned the carb?
