polaris trail boss 350l
Old Dec 1, 2007 | 08:30 PM
bjn's Avatar
bjn
Default polaris trail boss 350l
I was working on my polaris and I noticed on my crank case an oil fill plug and it says " 15cc of oil, I am not sure what kind of oil to put in here, it is a 2 stroke oil injected motor and I did not know that it needed oil in the crank case, can someone fill me in on this
Thank you
BJN
Old Dec 1, 2007 | 09:20 PM
ftwflh's Avatar
That is your counterbalance and it is the most important thing on a 400 to keep changed
Old Dec 1, 2007 | 09:42 PM
bjn's Avatar
bjn
Maybe I did not give you enough info, this is a trail boss 350 liquid cooled 2x4, I just want to know what kind of oil to put in the crank case, I didn't think I had to put oil in the crank case on a 2 cycle engine, but on the crankcase cover it says 15cc oil with an arrow pointing to a plug (not on the drain plug)
bjn
Old Dec 1, 2007 | 10:19 PM
ftwflh's Avatar
10w30 in the counterbalance fill the oil tank with 2stroke oil
Old Dec 1, 2007 | 10:21 PM
hoytultratec's Avatar
just changed all my fluids last night....Counterbalance is a pain...get yourself a manual it helps.
Old Dec 1, 2007 | 10:43 PM
bjn's Avatar
bjn
Thanks for the info
I removed the drain plug beside the recoil,but nothing came out, is this the right drainplug (looks like 10mm bolt)?
Also, do I only put in 15cc of oil
BJN
Old Dec 1, 2007 | 10:59 PM
that was the recoil drain plug probably you really need a manual there are 3 drains under there. the one in the middle of the motor is the counterbalance drain atleast mine is. oh yeah its 10mm with a philips slot in it,
Ean
Dec 19, 2022 08:48 AM
Nondem
Feb 22, 2020 12:20 PM
Gtsordo
Jul 13, 2015 10:38 PM
yambam13
Jul 4, 2015 01:49 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
