2 stroke gas and oil mix question
Old Dec 2, 2007 | 06:10 AM
New2ThisForum's Avatar
Default 2 stroke gas and oil mix question
i have a 1996 300 xplorer 4x4. should i use 2 cycle injector oil ONLY in the oil reservoir? and can i mix the gas and oil myself using regular 2 cycle oil and if so what mix ratio should i use?
thanks, Greg
Old Dec 2, 2007 | 07:59 AM
brutus450's Avatar
all i know is if you make the mix then you have to disable and block off the oil tank and pump
Old Dec 2, 2007 | 08:23 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
use only 2 stroke oil either way and it would be like 40 to 1 mix but i would stick w/ oil injection if it works or do what brutus said.
Old Dec 2, 2007 | 10:09 AM
hoytultratec's Avatar
why would you wanna premix when the oil pump works? premixing is a pain and polaris oil pumps are good. guess its your choice.
Old Dec 2, 2007 | 10:12 AM
ftwflh's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: hoytultratec
why would you wanna premix when the oil pump works? premixing is a pain and polaris oil pumps are good. guess its your choice.</end quote></div>
I totally agree.
No need to disable the injection system unless you are dropping weight or have a high HP engine.
Old Dec 2, 2007 | 04:29 PM
caperinmuskoka's Avatar
Ride like you own it, Not like it's stolen!
I never seen one fail yet!!!!...ATV's ...or SLEDS!!!!!.........Caper.........
Old Dec 2, 2007 | 04:45 PM
<div class="FTQUOTE"><begin quote>Originally posted by: caperinmuskoka
I never seen one fail yet!!!!...ATV's ...or SLEDS!!!!!.........Caper.........</end quote></div>
mine failed, but it was open letting tons of oil in....guess that was a good thing!
Old Dec 2, 2007 | 04:47 PM
and your right you dont see much pump problems causing the engine to burn up
Old Dec 2, 2007 | 04:55 PM
ftwflh's Avatar
Most of the time when it is oil failure it is due to a bad cable
Old Dec 3, 2007 | 12:50 PM
Thanks for welcoming me into your forum and thanks for the info. I'm not going to mix myself now. The only reason I was considering mixing was a friend of mine said he wouldn't trust the pump when you could mix it yourself but I trust you all and your knowledge and once again Thanks for the help.
Greg
tastyatv
May 28, 2023 11:11 PM
kelleycully
Sep 15, 2016 02:57 AM
Big bousse
Sep 26, 2015 10:42 AM
Anomers
Aug 16, 2015 11:06 AM
Ask the Editor
12
Jul 21, 2015 06:57 AM
