2 stroke gas and oil mix question
<div class="FTQUOTE"><begin quote>Originally posted by: hoytultratec
why would you wanna premix when the oil pump works? premixing is a pain and polaris oil pumps are good. guess its your choice.</end quote></div>
I totally agree.
No need to disable the injection system unless you are dropping weight or have a high HP engine.
I totally agree.
Thanks for welcoming me into your forum and thanks for the info. I'm not going to mix myself now. The only reason I was considering mixing was a friend of mine said he wouldn't trust the pump when you could mix it yourself but I trust you all and your knowledge and once again Thanks for the help.
Greg
Greg
