88 trail boss 250 starting problem
Old Dec 4, 2007 | 05:55 PM
thecreator's Avatar
Default 88 trail boss 250 starting problem
the oil line from the oil pump to the engine broke. it heated up and died. i replaced the oil line and the spark plug. still will not start. it turns over. this happened once before. after replacing the line, the plug, and turning it over for a while it started and ran fine. until now. any ideas? thanks.
Old Dec 4, 2007 | 07:11 PM
xler8ion's Avatar
Since the oiling system failed and it overheated it may be that the lack of lubrication hung a ring and broke it or the land. I would check the compression to see if there is damage and if that is not the prob then move on to the fuel and ignition
Old Dec 5, 2007 | 11:34 PM
CTATV's Avatar
yeah depending on your mechanical experience a compression test and opening that head up could reveal &/or rule out a lot
Old Dec 5, 2007 | 11:42 PM
thecreator's Avatar
it`s got plenty of compression and getting good spark. also getting fuel.
02Chevrolet
1) Engine problems..
Jun 23, 2015 12:12 AM
1000gade
May 27, 2015 12:37 PM
PolarisPower500
May 17, 2015 02:28 PM
EXtreme
Sep 10, 1999 12:54 PM
Matt24
Aug 3, 1999 07:46 PM
