Polaris Drop Hitch ball
Old Dec 5, 2007 | 02:29 PM
SpudRacer's Avatar
Default Polaris Drop Hitch ball
I got a 1" drop hitch from my Polaris dealer for my 08' 800HO. I went to Advanced Auto Parts to pick up a 2" ball to put on it to tow my trailer around the yard, but it wasn't until then that I noticed the hole where you would put the ball in is beveled. Wider at the top than the bottom, and the ball won't fit through. Is there a special ball I have to use with this hitch, or do I need to buy a different 1-1/4" draw bar?
Help out a newbie??
Thanks
Tom
Bryson City, NC
Old Dec 5, 2007 | 03:16 PM
Sunset Ed's Avatar
I would guess that they do not want you to put a 2" ball on it because that is generally for larger or heavier trailers. That is why it is only a 1 1/4" bar. You could be a step drill bit and bore it out.
Old Dec 5, 2007 | 04:44 PM
deanz400's Avatar
file it larger
Old Dec 5, 2007 | 05:55 PM
Brainerdian's Avatar
***** for hitches come with different size shafts for different size tow ratings. Bigger the shaft - bigger the weight capacity - higher the rating.
Either get a different size shaft or a different size receiver. I wouldn't drill it out or modify it because it <u>may</u> someday end up on the back of a car towing something too heavy and it would be a PITA.
I'm guessing you could probably get a less expensive drop receiver somewhere besides a Polaris dealer (Farm store).
Another thing I have found is a system called "Convert-a-ball". It allows you to change ball sizes on the same shaft without tools. Great if you've got different size trailers.
Old Dec 5, 2007 | 08:14 PM
JCDEYO25's Avatar
This is what I built.
http://www.pbase.com/rottweiler/jcdeyo25
John
Old Dec 5, 2007 | 08:38 PM
caperinmuskoka's Avatar
Ride like you own it, Not like it's stolen!
I use the hitch and ball from my car!!!.....SAME.....Caper........
Old Dec 5, 2007 | 11:02 PM
SpudRacer's Avatar
Thanks for all the suggestions. As for the draw bar ending up on the back of a car... I don't think I'd every own a car that only had a 1-1/4" hitch on it. I currently drive an 07' 4-door Rubicon. It's cool, but a gutless wonder.
I think drilling out the hole may work, but I don't have the tools to drill a hole that large through solid steel. I would have to farm that out...
Tom
Bryson City, NC
Old Dec 6, 2007 | 05:08 AM
Wenty's Avatar
Just buy the right ball, no need to buy a different hitch or drill it out. They make several different size shanks, 5/8", 3/4", 1", 1 1/4", ...
Old Dec 6, 2007 | 09:26 AM
deanz400's Avatar
measure the hole and buy the approate shaft
Old Dec 6, 2007 | 10:16 AM
OIown12's Avatar
I took my bar to the local U-Haul rental place and they fixed me right up. I know that a lot of folks on this board are the "if it don't fit, make it" type people. I personally am a "get the right tool for the job" kinda guy. Guess it's the Safety Officer in me.
Jul 22, 2015 05:00 AM
ltrmc02
Jul 22, 2015 04:50 AM
musselmark
Jul 17, 2015 02:40 PM
toonces
Jul 11, 2015 12:01 PM
Mikea1978
Jul 4, 2015 12:37 PM
