did my 300EX axle bend?
Old Dec 5, 2007 | 10:55 PM
strings's Avatar
Default did my 300EX axle bend?
I was riding in the snow on my 300ex and I came to a turn between two trees and my right tire caught one of the trees pretty good. Not enough to stop me but it was pretty hard. I wasn't going that fast. I was lugging it in second gear when it hit. I rode it on the road to see if I could feel a bend and I don't think it did bend but when i look at it it seams a little bent. It was about 22*F. out. So what do you guys think would the stock axle bend with a hit like that? Any HELP would be greatly apreciated.
strings
Old Dec 5, 2007 | 11:08 PM
CTATV's Avatar
probably not if it isnt riding funny or making any bad grinding noises i wouldnt wory about it. ive ripped trees like that more times then i can remember
Old Dec 5, 2007 | 11:15 PM
strings's Avatar
Thanks, I'm going to keep an eye on it and hope for the best!
Strings
Old Dec 6, 2007 | 01:38 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Put the rear up on a crate or something, and turn the wheels and see if anything is wobbling. Could have bent a rim, a hub, the axle, or nothing at all....
Old Dec 6, 2007 | 02:50 PM
strings's Avatar
Thanks for the reply I will try it when I get home. I got my fingers crossed!
strings
Old Dec 6, 2007 | 02:53 PM
deanz400's Avatar
if you don't feel like it then it probably isn't
Old Dec 7, 2007 | 12:50 PM
trx300man's Avatar
My experience is with a utility quad but my daughters rear axle was bent pretty bad and you could not feel it while riding unless you were on pavement. You should be able to look down at a rear wheel while moving and spot it right away. If it is wobbling on one side, switch rear wheels from side to side and look again. If the wobble moves it should be the rim, If the wobble stays on the same side, it would probably be the axle.
Old Dec 7, 2007 | 09:30 PM
strings's Avatar
I can't feel it on pavement but the wheel has a very slight wobble. I'll switch them tommorow and see what happens.
Strings
Roro
Ask the Editor
Sep 30, 2015 10:58 AM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Bonzhonda300ex
TheATVSuperStore
Sep 17, 2015 01:21 PM
ScopeZ_
Sep 13, 2015 07:55 AM
1000gade
Sep 9, 2015 04:41 PM
