polaris scrambler 2002 500 2/4
Old Dec 8, 2007 | 12:54 PM
sprinter10's Avatar
Default polaris scrambler 2002 500 2/4
I have a 2002 polaris scrambler 500 2/4 i got is used and it had a k and n air filter
i don't think it has a carb kit does it need one? does it need a different air box cover? I whant to get a clutch kit for it because i have oversiesed tires and i whant some more torque. when i first start it it runs fine besides that it gets loaded up when i first hit the gas or if i let it sit for over 3 seconds without hitting it it just sputer a lil then revs right up. after 10 to 15 minutes of riding the quad out of nowere stops the engine shakes and taps and then dies. 15 minutes later if fires back up. other times after 15 min it starts bogging a lil i look in the air box and see some oil coming out of the over flow in teh front of the air box and steam coming out. any ideas? idk who else to ask
Thanks for any help
Old Dec 8, 2007 | 08:18 PM
hoytultratec's Avatar
get rid of the over size tires....did you clean the carb? you dont need to do any airbox mods with a k n filter..you say shakes and taps might need the valves adjusted
Old Dec 8, 2007 | 09:39 PM
sprinter10's Avatar
yea i was thinking that but the people at the polaris dealer said that if it revs up fine when you first start it that it isn't the valves do i need a carb/jet kit for teh k&n air filter? thanks
Old Dec 8, 2007 | 10:06 PM
check the color of the plug and see if its running lean=white or gray coloring to the plug.
Old Dec 8, 2007 | 10:08 PM
if itlean you need to rejet it richer as far as overheating hows the thermostat it might be bad steam isfrom antifreeze.
Old Dec 8, 2007 | 10:12 PM
ftwflh's Avatar
clean the carb real good before you do anything
sprinter10's Avatar
the plug is black how hard is it to get to the thermostat and can u check it in a pot of water on the stove like others?
Old Dec 8, 2007 | 10:13 PM
ftwflh's Avatar
you dont have a over heating preoblem you have either a carb prolem or clutching
Old Dec 8, 2007 | 10:21 PM
sprinter10's Avatar
ok would a carb problem make the quad stall out 5 times after 15 minuts of riding but run fine 15 minutes later? the plug it black and it blows black smoke out the egsaust when i rev it and it backfires.
Old Dec 8, 2007 | 10:26 PM
ftwflh's Avatar
check the choke setting
