Need advice on homemade plow for Wolv...
Old Jan 9, 2001 | 09:51 PM
derekjes's Avatar
I got a good deal on a very well built plow for my Wolverine today, but there is one problem... I can't figure out a way to lift the blade. The bike it came off had a winch, which is how the plow was operated. I need to modify it to use a manual lifting device, but I'm not sure how. I was hoping someone here had built one before, or has some idea of how I can do it. The plow is built fairly heavy, so a leaver near the pivot point in the back is out of the question. Anyone have any ideas? Thanks.
Old Jan 10, 2001 | 12:20 PM
Dan98Warrior's Avatar
I saw one that used a cable over the front rack with a couple of pulleys. I don't know how heavy the plow is but with a little inginuity, you should be able to lift it witout much problem.
Old Jan 11, 2001 | 04:22 PM
asfastasu's Avatar
I had the same problem. Right now I use a come-a-long hooked on the front rack with the handle in the center of the handle bars. With one crank up it picks the plow up about 4". Then I just release the locks and let it fall down. It's crude, but it works until I can come up with something better.
Old Jan 15, 2001 | 11:14 PM
peregrine's Avatar
I believe that most after-market accessory manuf. offer something called a plow actuator that is supposed to be cheaper than a winch(kimpex,etc.) Also I don't think that the whole mounting assembly built for your quad is expensive, although I built my own that uses my winch. The one for your quad probably comes with a manual lift handle, and they are kinda slick
ultangler
Nov 30, 2024 01:35 AM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
kodiacrunner
Oct 4, 2015 11:52 AM
wrencher82
Sep 28, 2015 10:02 PM
