Injection Oil
Old Dec 10, 2007 | 08:32 PM
DEPALMA's Avatar
Default Injection Oil
If I have bel ray inj oil in my daughters e-ton can I add a synthetic inj oil if the opresent oil in there is not synthetic?
Old Dec 10, 2007 | 09:46 PM
TLC's Avatar
TLC
I just switched to full synthetic in my sled this year, and had 1/4 tank of regular injection oil nothing happened and that was 40 miles ago.
Old Dec 10, 2007 | 09:52 PM
onebigzj's Avatar
better to remove all oil from tank and refill with the new oil. have seen oils fight and brake down and lead to diaster
Old Dec 11, 2007 | 10:44 AM
dean4174's Avatar
Should i be using injection oil in a lt50?
Old Dec 11, 2007 | 11:36 AM
onebigzj's Avatar
if you add oil to a tank and its a 2 stroke.YES add injector oil. not reg 2stroke oil. if you premix use reg 2stroke oil
Old Dec 11, 2007 | 03:51 PM
dean4174's Avatar
Thanks for the reply onebigzj. Yes i add it to the tank, so ill use injector oil. would it do any harm if i used regular 2 stroke oil in the tank instead of injector oil?
Old Dec 11, 2007 | 06:31 PM
onebigzj's Avatar
you should only use injector oil in tank!!! that oil is made to be injected. in colder weather it will gell up and not flow if other is used. I learned that on sleds.
Old Dec 12, 2007 | 01:07 PM
dean4174's Avatar
ok, thanks for the help onebigzj.
Old Dec 12, 2007 | 02:32 PM
onebigzj's Avatar
no problem. glad I could help
Cummins Driver
Sep 11, 2019 01:22 PM
dwhipper61
Aug 27, 2015 11:01 AM
Ask the Editor
12
Jul 21, 2015 06:57 AM
