Need help with carb
Old Dec 14, 2007 | 07:41 PM
426honda's Avatar
Default Need help with carb
Alright ive been breaking in my 400ex and i need to kno where all the adjusting screws are. My idling is off and i need to adjust it and my fuel
Old Dec 14, 2007 | 07:54 PM
Marty1985's Avatar
Well as far as the idle is concerned on the 400ex its the big screw that sits underneath the float bowl. If you look at your carb from the lift side as if you were sitting on it looking at the choke lever you should see a big knurled **** with a slot cut for a flat blade screwdriver this is the idle speed screw, clockwise to increase idle RPM's and Counterclockwise to lower idle RPM's. As for the other adjustments, ive never went that far into tuning my carb but im sure recon would be able to help ya on that one.
Old Dec 15, 2007 | 01:52 AM
hondabuster's Avatar
The idle mixture screw, is located on the underside, just forward of the float bowl. It only controls the mixture of the idle circuit.
GregM
Mar 6, 2018 06:53 AM
GregM
Jul 29, 2015 09:41 PM
ghost civic
Jul 27, 2015 03:15 AM
Aitch
Jul 21, 2015 09:40 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
