82 110 atc carb help
Old Dec 21, 2007 | 05:16 PM
boosted96cobra's Avatar
Default 82 110 atc carb help
Picked up a 110 atc for the wife yesterday, had not ran in about a year.
Got it started this morning and drove it around in the new snow we got, what a blast!
I could not get it to idle and it had fuel running out of the bottom hole, so I decided to take the carb apart and clean it and see if the float was cracked or stuck. Everything looked good, had some crap in it. The float seemed fine. Put it back together, got it idling, but it is still leaking out of the hole.
The float was moving up just fine when I put it together. I have read somewere there is something you can "bend" to adjust it? Sorry I have been searching but cannot find were I read it. Or is it maybe just stuck? It didn't start leaking till I drove it around some, but it still is after I put it together.
Another question is on adjusting it...
In the picture above (thanx sansabar) there are two screw adjustments. Correct me if I am wrong but the upper on the middle of the carb is for idle, and the one on the lower left is for enrichment?
Thax for any help.
Old Dec 21, 2007 | 05:36 PM
125dillmatt's Avatar
it could be your overflow it helps to put a 3 inch gas line on it you might want to adjust your floater and for your idle sens its so old wat helps with mine to get it adjusted right let it warm up for about 5 to 10 minutes and the adjust your idle
Old Dec 21, 2007 | 06:53 PM
SMFREY's Avatar
Did you soak the carb and put a Kit in
Or just clean
I have 2 82-110s
Were it mine as I have done several in the last couple years
I would get the kit and soak
If your carb is like mine there is no tab to bend float is donught
Needle probable has nick leaking by
Ray
Old Dec 21, 2007 | 06:59 PM
SMFREY's Avatar
Sorry I did not read all
The two screws you refer to
The right you are correct is Idle should be about 1500 rpm +-
The other is air/fuel at idle should be about 1-3/8 turn to start
Let warm up before adjust
Also set your timing and adjust your cam chain tension
I have found with the age of these most have not been done in years
Ray
Old Dec 22, 2007 | 05:13 AM
FIX IT!!! The needle was not attached right with the throttle cable. I took the carb off and checked the float and all was fine. It was leaking on the air filter side of the carb, not the overflow. Starts first pull now too which was good considering it is about 20 degrees out.
I didn't know the needle was wrong, I put it back in how it came out, musta been a problem before, prolly why I got it so cheap.
I also adjusted the damn brake so it actually stops now too.
It will sit now till xmas, then the wife will ride it around the yard a bit, then when my manual shows up I can do a valve adjustment and then go after the bearings or whatever is worn in the back end of it.
Old Dec 22, 2007 | 05:55 AM
nice sounds good i bought mine for 50 dollers runs great the guy that sold it to me had some of the same problems have fun riding
GregM
Mar 6, 2018 06:53 AM
GregM
Jul 29, 2015 09:41 PM
ghost civic
Jul 27, 2015 03:15 AM
Aitch
Jul 21, 2015 09:40 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
