400ex top end problems:update
Old Dec 26, 2007 | 09:04 PM
bams400's Avatar
Default 400ex top end problems:update
i tore the top end apart so could see all the internals and everything looks tight except the gasket was a little tainted but notheing that really caught my eye i still have to check the valve seals. is there anything i should deffinately check before putting it back 2gether
p.s. the exhaust was only glowing on one side. ?
Old Dec 27, 2007 | 09:41 AM
go-hard-or-go-home's Avatar
first off y did you pull it apart?? second if everything is fine, i would check the head for wear, like to see if its warped, or if the valve lashes are to specs. also look at your rockers. check to see if theres wear there.
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
