Rear Wheel Studs
Old Dec 26, 2007 | 09:08 PM
Bigtimer's Avatar
Default Rear Wheel Studs
I have a 1884 Honda TRX 200 that has 2 rear wheel studs broken off. Can they be pressed out and replaced ? If so, where can I get them?
God Bless
Old Dec 28, 2007 | 10:25 PM
Bigtimer's Avatar
Come on, I'm sure someone has had to replace a wheel stud. Please help me out.
Old Dec 28, 2007 | 10:27 PM
juttin_15's Avatar
wow a 123 year old atv, yeah you can beat them out and go to the local atv store and you probably have to order them but i put a full set of studs in my 300ex
Old Dec 28, 2007 | 11:16 PM
Bigtimer's Avatar
I haven't tried to remove them yet, but I called my local Honda Dealer and they say that I have to buy the entire rear hub.
Old Dec 29, 2007 | 02:23 AM
KNOWSALOT's Avatar
The Facility
Studs from other models will work...just knock out one and carry it to the dealer if you intend on going back with parts as close to stock as possible. But frankly, I would knock the bad studs out and replace them with Grade 8 bolts and nuts....it accomplishes the same purpose. The only down side is having to use a wrench on the backside of the hub to hold the bolt when tightening or loosening....but that to is often remedied by a couple spot welds to hold the bolt in place. Common repair practices on machines of that age which arent usually worth the cost of high dollar ticket items but worthy enough to not donate to the scrap yard.
Old Dec 29, 2007 | 06:34 AM
Bigtimer's Avatar
KNOWSALOT, Thanks so much for the help. My next door neighbor is a pipe fitter and has a small wire welder in his shop. I'll knock em out today, pick up some grade 8 bolts & nuts from the hardware store and have him spot weld them in place. I did find the studs online but they were about $5.00 each and the nuts were almost $3.00 each + shipping! Your recommendation is much more practical for this older machine. I really appreciate you taking the time to answer my question.
God Bless and Happy New Year!!!!
Old Dec 29, 2007 | 11:41 AM
juttin_15's Avatar
i went to a yamaha dealer and got them for 1.50 a piece for nuts and 3.00 apiece for studs.
STLyamwar
Jul 25, 2020 04:44 AM
DFWSRT8
Aug 20, 2015 09:24 AM
mbkirk
Aug 14, 2015 08:20 PM
mbkirk
Technical and How-To Articles
Aug 14, 2015 08:12 PM
Bergmann
Aug 13, 2015 03:51 PM
