Anyone install Handgaurds on a Rubicon
Old Dec 28, 2007 | 11:23 AM
MACHZMISSLE's Avatar
Default Anyone install Handgaurds on a Rubicon
I just got some powermadd handgaurds for christmas and CANNOT figure out how they will ever fit with the rubicon controls. I have an 07 and I don't think anything has changed in the controls department on this rig.
I know there are a couple of tabs that need to be removed and I have done that but I still can't figure out how they will ever work.
If anyone can post a pic of your setup PLEASE help me out, or tell me a trick to make this work.
Old Dec 28, 2007 | 01:21 PM
Scheer's Avatar
I'm not too sure on the rubicon setup, but on the brake side of the handlebars on my rincon the cover was angled away from the brake fluid reservoir, twards the front of the bike. I just took and zip tied it so that it would snug up nice to the brake reservoir. Not sure if this helps or not, but just thought i would throw it out there for you.
Old Dec 28, 2007 | 02:14 PM
wyoelkhunter's Avatar
I put a set of maier hand guards on mine they sent me some other bolts for the brake levers, and used a zip tie to go around the resviour. The whole picture thing is still getting the best of me but I'll try to get one posted
Old Dec 28, 2007 | 10:32 PM
tramp's Avatar
I have power-madds on my rancher 420 plus the bracket for the snowplow actuator switch and winch control switch. You just have to loose the brake lever and the throttle and move them around, in or out, to make the mounts work. Seems like I have one hand guard mount to the outer most position and the opposite one mounted to the inside position. I didn't have too but you may have to remove the throttle spacer bar. They will work.........KEEP TRYING!
Old Dec 29, 2007 | 06:40 PM
I got them on, I was just being impatient. As soon as I seen a good picture of them installed it looked pretty easy. thanks fellas.
ReconBayou
Oct 31, 2022 05:37 PM
shimanok2
Jan 29, 2016 07:37 PM
2many2ride
Sep 27, 2015 04:35 AM
patrick.oc123
Sep 15, 2015 02:45 PM
