Air box lid on warrior
Old Jan 11, 2001 | 12:22 AM
thejerm14's Avatar
hey i have a pro design air filter and i don't want to run with an airbox lid but i am worried i will suck dirt into the engine through the breather hose that connectes to the snorkel. do any of you run with out a lid and how do you do it? thanx
Old Jan 11, 2001 | 01:14 AM
99WarMachine's Avatar
The breather hose is normally connected to the airbox intake snorkel, so it doesn't matter either way.
Old Jan 11, 2001 | 10:01 PM
Fourplay's Avatar
I built a small filter for mine(didn't want to take any chances)I found a plastic fitting(off an old dirt bike)that fits into the hose. That fits into a hole in the lid of a film container,the film container has small holes drilled in the bottom and is filled with some filter material from a home furnace.OK that sounds like too much work for a stupid little filter but I whipped it up in 5 minutes.Anyways you probably don't have a plastic airbox fitting from a 1979 PE175 in your basement(do you?)so go to your local bike dealer or auto parts store with the hose and see if you can find an inline fuel filter that fits it.And while your at it put a fuel filter on the short hose coming off the very top of the carb,that carb breather can let stuff into your float bowl. Mine sucked in some flower seeds that plugged up my main jet.
Old Jan 12, 2001 | 12:11 AM
A99wolverine's Avatar
k&n makes a breather hose filter, I have seen it on the dirtwheels 660 grizzly any small clamp on filter would work, or you can drill a hole in side of airbox and stick it in there, and its the same as if it was in the unfiltered snorkel.
Old Jan 12, 2001 | 01:44 AM
thejerm14's Avatar
thanks for the replies. i will take a look around my work on saturday. thanx
Old Jan 14, 2001 | 06:30 PM
foxracing005's Avatar
i have a 88' warrior and i run without a air box lid. I have a k&n filter and k&n outerwear it has been workin fine so far.
88' warrior dg head pipe and silencer, k&n filter, k&n outwear, pro tether kill switch, rear bumper, nerf bars, customized air box, painted rims
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
01ssls1
Sep 22, 2015 06:50 AM
