1996 warrior starting problems
Old Dec 30, 2007 | 12:37 AM
Chase07's Avatar
Default 1996 warrior starting problems
[img]i/expressions/face-icon-small-confused.gif[/img]I have a 96 warrior 350 that wont start. When i got it I was told it needed a stator and a coil.I replaced thoses and a new battery as well.When i try to start it i have nothing at all. It acts like theres no battery.It just dead battery in brand new full charged any ideas what might be wrong. i got this quadas a needs repaired. thanks Guys for any help
Old Dec 30, 2007 | 12:43 AM
Raptor450's Avatar
Have you checked the fuse? There is a fuse under the rear left fender that is common for falling apart (it's the glass type). It is in a water-proof rubber enclosure.
Old Dec 30, 2007 | 01:17 AM
Chase07's Avatar
yeppers i check the fuse it is a in line fuse in a weather proff rubber housing it has a blade type thanks also there is no lights or starter clicking turn over ect. just dead
Old Dec 30, 2007 | 01:26 AM
Raptor450's Avatar
Has anything been done to the wiring? Like has it been hacked on or anything? Maybe the key switch is bad? Or have you tried jumping from the battery + terminal to the terminal on the starter to make sure the battery is good and the engine is grounded?
Old Dec 30, 2007 | 02:06 AM
Chase07's Avatar
well the wiring looks like it has been messed with. looks like someone didnt know whatr they were doing? so i tried to get a different harnness but first on was wronf it had the wrong connections. second one i just put on tonignt wrong again . wrong conections for the cdi box . how can you test the key switch and the kill run switch? now 200 bucks latter and still in same spot [img]i/expressions/face-icon-small-disgusted.gif[/img] so i put the old one back on and try to figure out whats wrong
Old Dec 30, 2007 | 08:42 PM
mdebuck's Avatar
check and double check for shorts ......
Old Dec 30, 2007 | 08:51 PM
STRAIGHTUPDAHILL's Avatar
i'm wearing mine..lol
Old Dec 31, 2007 | 11:44 PM
Chase07's Avatar
well it might be the main switch key i tested with a multi.meter and found there is nothing betwwen the black and black/white wires and i have a another switch froma different harnness and there is something between thoses colors do you think that might be the problem?
Old Jan 1, 2008 | 09:39 AM
Raptor450's Avatar
It's very possible. The key switch just passes power through when the switch is turned to "on". So with the switch on you should get an ohm reading on the incoming and outgoing wires and with the switch off you should not get an ohm reading on these wires.
Old Jan 1, 2008 | 01:51 PM
Chase07's Avatar
ok i believe the red and brown wire has ohms when on and not when off the black/black-white wire dont have anything at all
njrider64
Jul 4, 2017 01:40 AM
Nelson
Jun 20, 2015 01:59 PM
mikey426
Jun 17, 2015 03:53 PM
garyt1975
Jun 5, 2015 08:53 AM
1000gade
May 27, 2015 12:37 PM
