Technical and How-To Articles Post your Tech Tips and How-to articles here. Photo illustrations welcome
electrical problem
Old Dec 31, 2007 | 12:47 PM
railroader77's Avatar
Default electrical problem
hello, i could use your expertise. i have a kazuma 50cc quad. the only way to start the quad is to jump the solenoid. the push button starter button will not kick the quad over. i have replaced the kill switch and solenoid. the weird thing is when the atv is running the starter switch will engage the starter, but only when it is running. any suggestions would be great. thanks brandon
Old Jan 2, 2008 | 12:25 AM
halfstack's Avatar
hey brandon. i just recently got one of these 50s in my shop and it was doing the same thing. have you tried holding the hand break when u try to start it. thats all that was wronge with this one. i done some research and found out that they have a safty to where the break has to be applied to start it. try that and let me know if that helps you out. bryan
Old Jan 2, 2008 | 11:48 AM
hey bryan, this atv does not have a hand brake. i even tried to hold down the foot brake and that did not work. i purchased this atv from a friend, and it had sit for about a year and was not started. it was working fine when it was parked. if there is anything else you can think of let me know. thanks brandon
Old Jan 17, 2008 | 02:29 PM
justincohee's Avatar
does it have a clutch lever same principle as the brake lever
Old Jan 17, 2008 | 03:38 PM
no it does not have a clutch handle either. only has a foot lever for the brake and we tried pushing it down. thanks
Old Jan 18, 2008 | 04:43 PM
kinda sounds like a voltage problem does it take a volt meter and check to see if your getting power to the selinoid windings then trace backwards from there using the voltmeter you should be able to find your problem that way
Old Jul 24, 2008 | 01:26 AM
paardema's Avatar
Default electrical problem"></title><script src=
Do you have any experience with the wiring? Specifically the coil wiring and kill switches. I have one of these things with no spark.
skinnyr6
Aug 25, 2023 02:18 AM
TheHood
Jul 26, 2015 09:51 AM
Chuck188
Jul 17, 2015 02:45 PM
Unzzy66
Jul 11, 2015 10:01 PM
ranvette
Jul 4, 2015 06:13 PM
