Okay, here goes again, Carbs...
Old Jan 4, 2008 | 06:49 PM
mtphotoguy's Avatar
Default Okay, here goes again, Carbs...
Well oh well, here we are in a New year! Happy New Years to all...
My question, concerns the carb on my 95 Kodiak 400 4x4 again, about a month ago, I posted a message about popping through the front of the carb, and it was suggested that I replace the "Pilot Jet" because I was running lean, well did that and still getting a pop every once in a while, especially when plowing snow, now I have not replaced the carb joint(intake) but have a hole in the rubber portion of the joint, and I am not well versed on bike engines, but was wondering...if it is possible, this hole in the joint is allow the engine to run lean?,
Please be easy on me, I am learning, but wanted to know if this could still be a problem?
Thanks for any help you can provide a newby
The carb was recently rebuilt by a yamaha ATV dealer, so if they knew what they were doing, I would expect it to be within specs
Dave
Old Jan 4, 2008 | 07:29 PM
beefy46172's Avatar
Loves To Ride!
That is your problem. You need to replace it ASAP. It will suck air through that, and it may not due it every time, and that will cause sporadic issues. Not to mention it is unfiltered air. We all learned at some point in time. [img]i/expressions/face-icon-small-smile.gif[/img]
Old Jan 4, 2008 | 09:07 PM
Doctorturbo's Avatar
GOT BOOST!
<div class="FTQUOTE"><begin quote>That is your problem. You need to replace it ASAP. It will suck air through that, and it may not due it every time, and that will cause sporadic issues. Not to mention it is unfiltered air. We all learned at some point in time. </end quote></div>
X2
Old Jan 4, 2008 | 11:31 PM
STRAIGHTUPDAHILL's Avatar
IT'S GOING TO RUN LEAN IN THE COLD BECAUSE THE FUEL DOES NOT ATOMIZE THE SAME AS WHEN WARM...ALSO SINCE QUADS DO NOT HAVE A WARM AIR BOX..THE CARB CAN ICE UP FROM MOISTURE IN THE AIR FREEZING IN THE VENTURI CHANGING IT'S SHAPE
Old Jan 5, 2008 | 12:00 AM
mtphotoguy's Avatar
It did the same thing when it was warmer back in September, so I don't think the temps are the problem at this time.
Thanks
FULL-THROTTLE
Mar 21, 2008 07:52 PM
1STXTIMERX
Jan 9, 2006 02:07 PM
ImASissy
Feb 28, 2005 01:11 AM
Rocks
Sep 12, 2004 01:54 PM
