SUNL Hanma 110CC is idling high...
Old Jan 5, 2008 | 04:00 PM
BeeCountyPawn's Avatar
Default SUNL Hanma 110CC is idling high...
After our small engine mech cleaned up the carb and got it running, for some reason he couldn't get the idle to go down even after he tried adjusting the screw. I am by no means a mechanic, but I've had to learn about these things the hard way. Is there anything else I can adjust so it doesn't move forward when supposed to be sitting still at idle. If I left something out or more information is needed just let me know. Thanks in advance.
Old Jan 5, 2008 | 05:20 PM
SilveradoSS's Avatar
Sounds like the throttle cable is bound up somewhere between the thumb control and the carb.
Old Jan 8, 2008 | 06:46 PM
spliffy's Avatar
There might be a adjustment on the actual throttle cable also, a screw with a nut, kinda like a turnbuckle, try making the cable shorter with it, by screwing the 2 ends together & that may work????
2quiker
Mar 22, 2022 08:36 PM
fordfaithful21
Dec 7, 2015 05:52 PM
Minimod
Sep 10, 2015 09:20 PM
Minimod
Sep 10, 2015 08:03 AM
MeadowlarkFarm
Sep 9, 2015 03:08 AM
