04' YFZ 450 Timing help Please!
Old Jan 11, 2008 | 01:22 AM
TurboLTR's Avatar
Default 04' YFZ 450 Timing help Please!
So my little sisters timing was off due to bad tensioner. I put the cam sprockets back where they should be at TDC. It wont start. I checked the valve clearence and they are to tight. Does that mean it is not starting because the valves are open a little during the compression stroke? if so I just need to replace the shims. thanks for any advice from those who have been there lol PS yes its getting fuel and spark. and I know how the cam sprockets go. thanks!
Old Jan 11, 2008 | 12:18 PM
YurFatMom's Avatar
Did you have the flywheel marks lined up at the same time that you had the cam marks lined up?
Old Jan 12, 2008 | 02:39 AM
TurboLTR's Avatar
Ya, TDC was lined up at the time the cam sprocket marks were lined up.
Old Jan 13, 2008 | 01:52 AM
TurboLTR's Avatar
So incase anyone runs into this problem, it was the valve clearence. A little shimmin and she fired up and purrrrrd, mmmmm.
Old Mar 20, 2008 | 09:17 PM
Chawness's Avatar
Did the valves have to much shim or not enough? Im having the same issue...
Sjrpp
May 2, 2023 03:59 PM
slowgsxr97
Mar 18, 2022 03:40 AM
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
95wolv
Jul 17, 2015 08:13 PM
