plastic skid plates
Old Jan 14, 2008 | 02:32 PM
SalsCREW's Avatar
Default plastic skid plates
I'm interested in using a high end plastic skid plate on my Kodiak. Has anyone tried out either brand Armordillo or Perfex? If I'm not mistaken I believe they are both Canadian manufacturers. I found someone from Perfex on this site and tried to e-mail questions but the e-mail bounced back. I'd entertain the thought of going back to aluminum but I'm curious of the plastic's slick ability and bump absorption. Also the other catch is swaping out the skid plate for the plow mount (Warn plow system) every winter. This would be the case I guess for either plastic or aluminum.
thanks for the input
Old Jan 15, 2008 | 02:04 PM
deanz400's Avatar
I've made my own plastic plates and only had good experiences with them ,slide over logs and don't hang up on rocks like alum.
Old Jan 16, 2008 | 11:08 AM
CraZySteve's Avatar
I bought a few of the Yamaha skids for my Grizzly 450... they are ok but beat down a bit.. I am fortunate enough to have access to a metal shop.. so I am making my own 1/4" 5052 AL Front Skid plate modeled off the plastic stock one... and I am making custom Footwell skid plates out of 3/16" 5052 AL I am also going to be stiffening up my belly skid and rear with some 1/4" 5052. [img]i/expressions/face-icon-small-smile.gif[/img]
Old Jan 20, 2008 | 01:12 PM
hutch42's Avatar
I use plastic skids on my kodiak and they are definitly better than alu. Also I plow as well and built my own plow mount. The advatadge to the plow mnt is it is mounted to front whinch plate so no loss of ground clearance and I can remove plow in 3 pins in about 2to3 min. The skids slide better and softens bottom outs.Disadvantadge is factory skids wear faster but if you can find sheets of a good qual plastic make your own they will last longer then quad. Note a am looking for a good plasic as well if you find something please post. Ride On
Old Jan 21, 2008 | 12:14 AM
CaptainQuint's Avatar
A friend of mine uses plastic skids on his Outlander 800. He fabbed his own out of some white HDPE or Nylon I can't remember what the exact plastic is. It is really dense and tough. It also is sort of "greasy" and it slides over rocks and trees quite nicely. He's had his ever since the Outty came out and they're holding up great last time I seen them. He got the material at the local industrial materials jobber. The stuff is like a half inch thick or a little more. Easy to work with he said. He did his on machine tools but you could work it with common woodworking tools.
I'm my experience the plastic tends to slide over rocks and such better than aluminum. Aluminum may be a bit tougher but it seems to grab on the rocks.
Old Jan 21, 2008 | 12:38 AM
hutch42's Avatar
thanks for the reply i will look into this, and i do agree plastic is better ride on.//
Old Jan 21, 2008 | 01:08 AM
RickCJ7's Avatar
plastic skids! LOL!!!! what garbage!
Old Jan 21, 2008 | 03:24 PM
SalsCREW's Avatar
Here is some more info on these products. I can find info on the Armodillo but next to nothing on Perfex. ATVtires.ca sells both but pushes the Armordillo. The one thing I noticed on the Perfex is that they are pre-bent (no heating required). I've used aluminum and also made my own in the passed, I'm willing to try the Armodillo palstic out, anything is better than the stock junk.
http://www.atvtires.ca/ARMORDI...STIC%20SKIDPLATES.htm
http://quads.ca/tech_armordillo_skid_plate.htm
Old Jan 21, 2008 | 07:11 PM
BradW's Avatar
There are several championship rock-crawlers that use plastic skids(mounted over steel) on their buggies because it slides over rocks so well. I don't know what it's called, but it's the same material that cutting boards are made from.
Old Jan 22, 2008 | 10:09 AM
SalsCREW's Avatar
That's the best of both worlds right there. A plastic skin over steel or aluminum
