plastic skid plates
Old Jan 22, 2008 | 09:52 PM
hutch42's Avatar
Default plastic skid plates
thanks alot for info, and i must say you did a great job on yours. i see you raise your quad as i do and like you i have done the gas thing. i herd from a local he used plastic from the border of a indoor skating ring,and it has lasted four years so far and he was able to extend the plastic out under foot rest, and now he is hang free. crawl on and if you can't stay on all 4 then 2 is good.
Old Jan 23, 2008 | 01:11 AM
HeftyLefty's Avatar
If you're a DIY type check out the UMHW material. Check with Holtz Racing for pre made.
Old Jan 23, 2008 | 02:10 PM
SalsCREW's Avatar
Custom building my own may be an option
I looked into some on-line distributors of UHMW plastic (I haven't called any local plastic suppliers yet)
Here's a good one - http://www.onlinemetals.com/me...es&id=790&top_cat=181
1/4"x36"x48" sheet will run about $80 plus shipping. Add another $20 for a 1/2"x12"x12" to cut a front bash plate.
The 3x4 ft sheet should be enough to cover the bottom and possibly width wise to extend under the foot rests. There maybe enough left over to cut A-arm gaurds so for a little over $100 I could build a super slick skid plate. But it would be only as good as the hardware that holds it on. Otherwise I'll end up with a bunch of expensive cutting boards.
Anyone have any ideas for hardware or know if any aluminum skid plate manufacturers that sell mounting hardware separate for replacements or something?
I also found some tips on cutting the stuff-
http://www.shopfloortalk.com/f...showthread.php?t=6789
thanks for all of the input. I'll post the results if I build my own.
Old Jan 23, 2008 | 03:15 PM
HeftyLefty's Avatar
I don't want to ruffle feathers here by posting a link to another forum, but here is a link to a discussion of UMHW skids at PRC forum.com.
http://www.prcforum.com/topic.asp?TOPIC_ID=6363
Hope this helps you build it right.
Hefty
Old Jan 24, 2008 | 05:30 AM
  #15
CaptainQuint's Avatar
Ultra-High Molecular Weight Polyethylene. That's the stuff I was thinking of. Called my friend today and asked him what he used. He said they were still holding up fine. His Outty on the other hand is a bit banged up at the moment....
Old Jan 31, 2008 | 04:51 PM
  #16
SalsCREW's Avatar
Wow there's a lot of info out there on the web when you get into something -
HDPE vs UHMW
http://www.practicalmachinist....owthread.php?t=150907
Another option for plastic, lower cost but at a 1/2" thick it should make up for the difference between the two materials as far as durability
HDPE MarinaBoard Black 1/2"x24"x54"
Price: $79.06
MarinaBoard is a High Density Polyethylene formulated for the marine industry
PERFORMANCE CHARACTERISTICS:
High degree of stability
Good flexibility and toughness
Ultraviolet (UV) stabilized to resist direct sunlight degradation throughout
More product info here:
http://thecuttingboardfactory....oduct_Code=MBB50-24054
Old Feb 6, 2008 | 10:46 PM
  #17
brpbear's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: RickCJ7
plastic skids! LOL!!!! what garbage!</end quote></div>
Tell me what you don't like about them because I have used them for years and like them.
Old Feb 7, 2008 | 04:48 PM
  #18
BAIR's Avatar
The plastic skid plates are standard on the Suzuki King Quads... they cannot be all bad...
wendal
Aug 3, 2024 10:03 PM
Joe454
Nov 20, 2020 01:19 PM
Oct 10, 2015 10:20 AM
tysonbully
Sep 28, 2015 02:30 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
