07 grizzly 700 HELP !!!
buddy has an 07 grizzy 700FI and went and played in the water with it. everything was running fine then all of a sudden it started running like crap. wouldnt clean up on top or idle down low. now has hard time starting and still wont idle or clean up on top. any ideas?
LOL... stroker101... you own one and you still asked if it got water in the carb?
Anyways... gemini... Does it act like the rev-limiter is kicking in early? Does the reverse light flicker?
has he checked the sparkplug?
Also, he might want to take a look at the fuel vent to see if it sucked anything in it. It's located on the right side of the gas tank.
if you pin the throttle and hold it, when it gets to a high rpm it will eventually clean up. plug is kinda dark but doesnt look bad enough to cause this much headache. do yall think its an electrical issue or mechanical. we drained the tank to amke sure there wasnt any water or any other junk in it. any other ideas?
