front hub
Old Jan 17, 2008 | 10:46 PM
atvrider007's Avatar
Default front hub
wut type of oil do u use in the front hub and also wut would be the best pipe for and 500 scrambler thanks
Old Jan 18, 2008 | 01:55 AM
03scrambler500's Avatar
Default front hub
You should use the Polaris demand drive hub fluid. But I have heard of people useing ATF type F fluid and it working fine too. I have the Pro Circuit T-4 full system on my Scrambler 500 and love it. For a slip on I have heard that the White Brothers E serires is good. My brother has that on his Scrambler and he likes it. I gained more power with the Pro Circuit becuase it was a full system but it is also alot more expensive and a little louder too. If you have anymore question feel free to ask.
Old Jan 18, 2008 | 02:02 AM
TLC's Avatar
TLC
Default front hub
Play it safe and get the Polaris stuff for the hubs . Use ATF to flush the hubs out though.
Old Jan 18, 2008 | 10:27 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
Default front hub
imo. unless you got water in the front end/hubs you really shouldnt need to flush out the hubs. but use the right hub fluid for the job.
Old Jan 18, 2008 | 10:36 AM
Default front hub
just so everybody knows the factory service manual from Polaris tells you to "Fill with Polaris Demand Drvie Hub Fluid or Type F Automatic Transmission Fluid" I would nver think that Polaris would tell you to use anything else but their fluid but its right in the book. But I do only use the Polaris stuff becuase its designed by them for their hubs not something that is designed for a transmision that will work with the hubs.
Old Jan 18, 2008 | 10:44 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
Default front hub
this must be an older model. the new style takes only the correct fluid. good info to have 03 scram.
Old Jan 18, 2008 | 10:47 AM
Default front hub
that info came out of a 2004-2006 Polaris Scrambler 500 service manual.
STLyamwar
Jul 25, 2020 04:44 AM
toonces
Aug 6, 2015 10:46 AM
toonces
Aug 5, 2015 05:55 PM
carolinabomb
Jul 26, 2015 08:40 AM
tporath
Jul 11, 2015 12:31 PM
