Technical and How-To Articles Post your Tech Tips and How-to articles here. Photo illustrations welcome
how to break in a new piston
Old Jan 20, 2008 | 03:00 AM
iceracer01's Avatar
Default how to break in a new piston
what is a good way to break in a new piston on a lt250r and fresh bore
Old Jan 26, 2008 | 03:01 AM
ZButcheR's Avatar
Breakin tip's
Again
Old Jan 26, 2008 | 04:27 AM
iceracer01's Avatar
thanks alot i found that site very helpfull lots of good info there i have heard to run it hard but i was not sure it all makes sence now im going to pound it in the ground lol thanks again
Old Jan 26, 2008 | 11:24 AM
ZButcheR's Avatar
NP Bud good luck with the new motor....
Old Feb 5, 2008 | 03:39 PM
dan92's Avatar
thats a great web site. i never knew you had to get on the gas to break it in.
Old Feb 8, 2008 | 12:59 AM
Gimpster's Avatar
FACT that he does not apply...
Initial start-up is the most important step in engine break in.
Even though the machining process has been done to the engine before assembly, the engine must finish machining itself when first started. Starting the engine and letting it idle at around 1200 rpm until the head is hot to the touch is crucial to how long the engine will last. Once the engine head temp is hot, let it totally cool, start and let idle again until hot to the touch, let completely cool. Repeat this proceedure at least 5 times. It gives engine components ample time to finish their own machining of the new parts to each other. Starting a fresh engine and giving it hard throttle from the get go will cause new parts to chatter. This can cause premature wear on roller and slipper bearings, ring lands and pistons as well as cylinders.
At least he states warm it up first, so the engines own finishing machining process can begin... Then ride it like it was a rental !
In the past 27 years I can honestly say thousands of engines I have built is an understatement. I don't claim to be the best, as I have had one fail in that amount of years. Other engine builders like the legendary Hank Scott agrees with this warm up technique for initial break in.
----- Gimpster -----
Old Feb 8, 2008 | 01:03 PM
ZButcheR's Avatar
Very good point Gimpster...
But inless you are doing the rebuild yourself, or unpacking your new motor from a crate, not to many people get to run there motor for the 1st time.
If your picking up a new quad/bike, from the dealer, who ever assembeld it ran it 1st, & he is the only 1 who know's what went on the 1st time it ran, Heck he could have road it up & down the parking lot in 1st gear pinned..(just sayin)
But very good info, sound's like you know your way around a motor.....
Old Feb 9, 2008 | 04:23 PM
Gimpster's Avatar
I have given our set-up fellers a piece of my mind quite a few times for over revving new motors... hehehe
I work at a a honda dealership, senior tech (been with honda since 86) and in my spare time I build engines. My hobbies include racing upright Mini Sprints whitch is a midget chassis with superbike engines as power plants
----- gimpster -----
Old Feb 10, 2008 | 03:18 PM
bwilcox's Avatar
I bought two new Hi bird 250s. I assembled them myself, started them up, let them warm up and then tried to ride them like I sole them. They both have very little torque and fourth gear is useless. Can you give me some tips on more torque and speed?
Thanks in advance.
exmotocrosser
Sep 13, 2019 06:12 AM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
nastyblaster100
Sep 13, 2015 01:19 PM
atvcollector
Sep 8, 2015 05:11 PM
