Kolpin bogging down
Old Jan 21, 2008 | 11:23 AM
lojodave's Avatar
Default Kolpin bogging down
My son has a 90 cc Kolpin. It starts and idles fine; but dies when you put any load on it. I changed the plug, cleaned the air filter, however, it just bogs down when you try to accelerate. could the carb need adjusting/what are the adjustments?
Old Jan 22, 2008 | 01:09 AM
hotblooded's Avatar
It sounds to me like the carb needs to be cleaned. If it ran good at one point it shouldn't need to be re adjusted. There is alot of things it could be just start with the simplest. We clean our carb between every race, from what happens to us if it gets dirty it is going to affect off idle and midrange the most.
Old Jan 22, 2008 | 01:10 AM
hotblooded's Avatar
One more thing, make sure that your spark arrester isn't plugged up creating to much back presure.
Old Jan 23, 2008 | 11:17 AM
lojodave's Avatar
Thanks...i cleaned the carb and added a little dry gas to the tank (we live in snow country and I think there might be a water/fuel issue). Both seemed to help alot. However, I do notice the accelartion is not very responsive. When I press the throttle, the rpms start slow and it takes a couple of seconds for the engine to respond.
hueby
Nov 6, 2015 11:34 AM
handyjc1
ATC 3-Wheelers
Oct 23, 2015 07:15 PM
Sassinm1
Sep 30, 2015 04:23 AM
essonlaker
Sep 10, 2015 01:12 PM
spark1051
Utility ATVs
Sep 4, 2015 07:58 PM
