Yamaha warrior stage 2 cam?
I am looking for some info. on putting a stage 2 cam in my warrior. I can install it, but I am wondering if it makes a difference in performance. Also can I run a stage 2 cam with stock valves and rockers. I have a DG exhaust system, jet, and a K&N filter. Other than that it is stock. Thanks for any info!
Any cam will make a difference in performance. I recommend the Webcam .430" (84 grind) with heavy duty valve springs. This cam will make a huge difference. If you decide to go with the Hotcam stage 2, you can run the stock valves and rockers, but you may need the heavy duty valve springs.
Elkaholic
09-06-2015 02:44 PM
