400 trailblazer
Old Jan 22, 2008 | 12:08 PM
Sandman2.0's Avatar
Default 400 trailblazer
New guy here
I'm going to look at an 03 400 trailblazer this friday. Can you tell me what things I should be looking for or at? Owner says it has hardly been used. I've had other ATV's before but never a Polaris. I would think a 400CC 2 stroke would really rock. Any info would be greatly appreciated.
Old Jan 22, 2008 | 02:02 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
check out chain,spockets and the swing arm bushings from being worn out for sure.
Old Jan 22, 2008 | 07:07 PM
ftwflh's Avatar
also check the counter balance for water or not having oil.it is located on the motor under the carb.This is VERY important
Old Jan 23, 2008 | 09:21 AM
Sandman2.0's Avatar
Thanks
Is it easy to check? How would I go about checking it?
Old Jan 23, 2008 | 10:07 AM
dwhst9's Avatar
Remove the seat and look straight down under the carb. You will see a tall fitting (it's the counterbalancer dipstick) with a large slot in the top of it. Take a LONG screwdriver and remove it. You should see oil on it.
Old Jan 23, 2008 | 10:10 AM
Sandman2.0's Avatar
Great thanks!
neo27ny
May 14, 2018 12:19 PM
chewy78
Sep 8, 2015 10:37 AM
tmboy
Technical and How-To Articles
Sep 1, 2015 09:20 AM
suzukiquadrunner1987
Aug 6, 2015 03:59 PM
shewshew989
Jul 14, 2015 03:09 AM
