Magnum 425 sputtering and backfiring
Old Jan 24, 2008 | 09:54 PM
tedsxb's Avatar
Default Magnum 425 sputtering and backfiring
I trying to help a friend fix his 1995 Magnum 425 2x4. It starts and idles fine, but if you give it any gas above 1/4 throttle, it starts missing and sputtering and it will occaisionally backfire loudly out the muffler. I replaced the spark plug and cleaned the air filter only about a month or so ago (I usually do the maintenance on the quad). It is also MUCH WORSE WHILE IN GEAR. The greater the load, the worse it does it. It doesnt seem to matter if the choke is on or off. Is this a fuel issue or a ignition issue? What should I do? TIA
Old Jan 24, 2008 | 10:27 PM
ftwflh's Avatar
Sounds like a bad cam
Old Jan 25, 2008 | 12:57 AM
goodblasson's Avatar
I have the same problem... I ordered new nozzle, jet needles, and few other internal carb parts. I hope this will fix it, I will post my results in the next week or so after I do the install. I too have read that the cam could be the issue. Are you fouling spark plugs easily?
Old Jan 25, 2008 | 09:26 AM
Kerbbirds's Avatar
Souunds like the cam but check to make sure the etc is adjusted correctly and there isnt gas in the oil, sometimes the needle and seat go bad and fill the crankcase with gas. Maybe clean the carb.
Old Jan 25, 2008 | 12:59 PM
mkgearhead's Avatar
My '96 did the same thing when I got it. It got worse when it warmed up. I got lucky. The valves were adjusted way too tight and weren't closing all the way. I'd check that first and make sure the lobes on the cam aren't flat.
Old Jan 25, 2008 | 01:50 PM
tedsxb's Avatar
How does a cam go bad? I have never heard of a cam going bad, i didnt think it was possible!! How do you check if its bad?
Old Jan 25, 2008 | 01:59 PM
mkgearhead's Avatar
When you take the rocker cover off to check the valve adjustment, just look at the cam lobes and make sure they arent flat.
Old Jan 25, 2008 | 07:48 PM
ftwflh's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: tedsxb
How does a cam go bad? I have never heard of a cam going bad, i didnt think it was possible!! How do you check if its bad?</end quote></div>
In the early-mid 90s Polaris had an oil problem to the topend that ate up cams in a hurry.This is the reason for the 0w40 synthetic oil and frequent oil changes.
Old Jan 27, 2008 | 07:09 PM
tedsxb's Avatar
Another question, why would a bad cam allow it to start and idle fine? I thought that the valve movemet (besides speed obviously) wouldnt change at idle
Old Jan 28, 2008 | 10:26 PM
tedsxb's Avatar
bump for suggestions
