TRX350D - no spark and I'm tearing my hair out
Old Jan 25, 2008 | 07:31 AM
clod-hopper's Avatar
Default TRX350D - no spark and I'm tearing my hair out
Hi folks!
New here and I'm already on the scrounge for help! [img]i/expressions/face-icon-small-wink.gif[/img]
I have an '88 model TRX350D with no spark, and I get the feeling that I've either exhausted all avenues of testing or am overlooking something particularly simple and stupid.
The first question has to be: Does anyone out there have a wiring diagram for this model??
I managed to obtain the diagram for the '87 model but there are a few key differences, and nearly all with the ignition system.
The list of testing so far is as follows;
Tested and eliminated coil
Continuity tested every ignition-related circuit in the wiring harness/loom
Replaced faulty pickup coil
Replaced burnt-out phase wire from generator coil (including the single phase exciter to the cdi) and bench tested generator windings.
Checked operation of the engine kill/stop circuits.
Eliminated the fuel pump relay as a possible cause of the ignition pulse being earthed.
Aaaaaand....
Everything seems to check out but still no spark!!
From what I can tell I've now tested everything except the cdi itself (would like to get a wiring diagram to be sure), and not only can I not get any test data for it but my local specialist can't either.
So - Question number 2: Any ideas???
Thanks & Regards
Dom
Old Jan 25, 2008 | 07:40 AM
HondaMechanic's Avatar
PM your email address and I will email you the wiring , ignition , and switches sections from the 1996-93 TRX350D PDF Honda shop manual ...
Old Jan 25, 2008 | 07:46 AM
PM sent
Can't thank you enough for that!
Regards
Dom
Old Jan 25, 2008 | 08:27 AM
TLC's Avatar
TLC
Did you check the stator? (Linky)
Old Jan 25, 2008 | 07:16 PM
Bounce400ex's Avatar
On a 400ex the test for the ignition control module is to verify that the rest of the system is working. I'm not sure if this applies here or not. It would explain why there is no test data available. Just a thought.
Old Mar 22, 2008 | 01:52 AM
fixitfirstime's Avatar
I had the same experience on my 1988. It turned out to be the cdi computer. The good news is the changes you talked about made it compatible with up to and including 2000 foreman 400. That is the box I am running and it seems to work fine.
Old Mar 22, 2008 | 01:54 AM
On second thought...you don't need this emotional roller coaster. Just let me know where to come to you and I will get that old thing out of your sight before quick!
Old Jun 21, 2011 | 03:57 PM
oldstambo's Avatar
paph@att.net
jeepwheelin02
1) Engine problems..
Jul 18, 2020 06:42 PM
Shainasmash
May 8, 2017 06:38 PM
hueby
Aug 29, 2015 08:34 AM
hueby
Aug 28, 2015 07:26 PM
vinrum
11
Aug 26, 2015 06:44 AM
